sweat copper to brass?
Old 04-13-07, 02:35 PM
Is that possible? If so, is it the same procedure as copper on the brass end - debur, flux, etc?
Old 04-13-07, 04:43 PM
G
Received 31 Upvotes on 29 Posts
Yes you can and yes you do. I suggest you brighten both surfaces, don't touch the brightened surface, apply heat to the opposite side of the fitting to insure proper heat, give it a swipe of solder and you're done. Have a good one. Geo
