Looking for a 4" sanitary tee with two 2" inlets
Old 05-26-07, 03:17 PM
Does this exist?
My drain is a 4" line and I currently have a 4" santee with a 1.5" inlet on the side.
I want to change that so I can run two drains into it, one for a new washer standpipe (2") and a larger washtub drain (2"). I would like the 2" inlets to be 90deg from each other rather than 180deg.
I looked at Home Depot and found nothing.
Old 05-27-07, 08:30 AM
shacko's Avatar
Does this exsist
You didn't say what type of pipe you had. If I understand you right you need a double tee or wye, you have to get these from a plumbing supply. They have two outlets, one on each side. These should be used on the vertical only. Best that I can do.
