installing sharkbite T in copper line...
Old 06-10-07, 06:16 AM
K
Anyone have advice on inserting a sharkbite T in a run of copper? Trying to run a line off of an existing 3/4" copper line. As I understand it, with a standard copper T, I'd cut a little more off and use a 3/4" sleeve to slide one end of the line in (not sure if I'm saying that clearly).
I'd like to just make my cuts and add the T in, but figure I'm going to have an issue fitting both ends in. I don't imagine the copper will have enough flex to fit the second end in after securing one side.
Thanks!
Kevin
Old 06-10-07, 06:45 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
Shark bite is the way to go. You should be able to release the holders on the copper enough to flex it enough to apply the sharkbite fitting.
Old 06-11-07, 03:48 AM
K
thanks
Thanks - I checked both ends of the existing line and it does look like I can push it out enough to get the shark bite T in there. Appreciate the response.
-k-
