Joining Schedule 40 PVC and metal
I replaced the piping around my sprinkler system vacuum breaker. Where the metal nipple goes into a threaded Schedule 40 PVC female fitting, I have a leak. I used teflon tape, but was concerned about cracking the fitting by over-tightening and may not have run it in as hard as possible.
My question is: when I re-do this, is there a metal-to-PVC pipe dope that would be better than the teflon tape? And is there a rule of thumb for avoiding cracking the plastic part you are running the metal into?
Great forum, as usual.
-Gary
-Gary
Just a point of interest.
There was a time that PVC female couplers were not a legal connection because of the cracking associated with these joints. (just because a fitting is made does not make it legal) I know this is about a sprinkler system and doesn't really fall under the plumbing code, per se, but for a future reference. Check the local code to see if this is an allowable connection.
Furd: your not a plumber, we don't read directions or labels....Good call.
Not all pipe dope is created equal so follow Furd's advice.
Good info; should I re-do with male fittings?
Thanks to furd and notuboo. I was trying to rebuild this piping exactly as it had been, and your feedback confirms my suspicion about the plastic female coupler. Since I am connecting the Schedule 40 to metal ball valves with female threads, maybe I should revise the plan and use male fittings, which I take it are preferable.
Gary
Gary
Received 38 Upvotes
Nope, I'm not a plumber. I am a retired engineer but I have made more threaded pipe connections than I care to remember. I have seen (and used) some plastic female thread adapters that have a steel band on the outside but I agree that if one can avoid using plastic female adapters that is the best solution.
