How to adjust tub drain lever?
Old 07-05-07, 04:43 PM
N
I noticed that the bathtub that the kids use is not holding water. I can hear it leaking into the drain. My question is how do I adjust the drain lever? It's the standard lever that you move up and down, not connected to the tub spout. It's held in place by 2 screws I removed the screws to look inside but nothing really looked obvious to me as to how to adjust it.
Any help would be appreciated.
Old 07-05-07, 08:12 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Undo the two screws and slowly pull the cover plate off. With it, will come a linkage with a turnbuckle on it. Take up on the linage a little and reinstall it. It should allow complete closing of the plunger, now. If not, you can keep trying different settings.
