Help Installing Supply Line for Ice Maker
Old 07-09-07, 07:33 PM
I'll be soon getting a new refridgerator and I want to be able to use the ice maker that it comes with. The problem is that I don't have a supply line for the ice maker. I checked some of the ice maker kits and they all seem to come with the saddle connection which I heard is no the best to use and I'm not sure if I have the space to use it. Once I have the fitting, running a copper line will not be a problem, I don't think. I'll just run it along the back of the cabinet. I live in a condo, so I don't have the option to run it from above or below.
Hot and Cold valves
http://mcclendonsplace.com/images/kitchen_plumbing.jpg
Cold Valve Side
http://mcclendonsplace.com/images/cold_valve.jpg
If you need to see different angles, let me know, I can take different pictures.
Old 07-09-07, 09:50 PM
Received 16 Votes on 14 Posts
I suggest that you use a pre-made braided stainless steel hose assembly for the icemaker supply. They are relatively inexpensive ($10-15) and much easier than making your own from copper tubing.
Adapt the hose to the outlet of your cold water shut-off valve. You will need a tee, preferably with a reverse compression on one connection but that may be difficult to find, so a regular brass pipe tee with three appropriately sized compression fittings and a "coupler" made from a short piece of copper with compression nuts and ferrules.
Old 07-10-07, 04:28 AM
When you say adapt the hose are you talking about the flex tubing that goes to the acutal tubing. If so, I think I understand.
1) Shut off cold water supply under sink
2) Disconnect the end that goes to the faucet (leave end to valve connected)
3) Connect a brass tee
4) Connect one end of tee back to facuet with new flex tubing
5) Connect other end of tee for water supply to ice maker
I'm not sure what the coupler would be used for.
Old 07-10-07, 11:17 AM
I had one more question before I do this. If I run the copper tubing that comes with the ice maker kits (I'll need about 20' - 25') can I run it behind the stove/oven safely. The reason is that my stove and refrigerator are on the same wall and I will have to pass my stove to get to the refrigerator. My plan was to run the copper tubing from under the sink through the back of the cabinets. Once I make the turn I would drop it down to the baseboard and continue to run it until I get to the refrigerator to make the connection.
I checked behind my stove and there is a gap down by the floor. Although the stove is pushed against the wall, the bottom back portion of the stove where the gas line connects is somewhat hollow.
I just wanted to make sure that there would be no heat concerns with the tubing behind the stove. I'm in a condo, so no access above or below.
Diagram of my kitchen
http://mcclendonsplace.com/images/kitchen_layout.jpg
Old 07-10-07, 11:48 AM
mattison's Avatar
You should be fine.
Old 01-22-08, 03:02 PM
Re: Your Ice maker install...
I believe I'm attemtping the same project you were last year. Looking at your pics I have the same setup under my sink and like yourself I am in a condo with no other options available. Are you able to use the saddle valve on the flex? Is the horizontal copper line, going to a dishwasher, a hot water line?
Thank you
Hot and Cold valves
Cold Valve Side
HTML code is On
