Plugging cast iron waste pipe
Old 07-19-07, 05:52 PM
I have a 6" cast iron waste pipe that I am not going to be using anymore. Two questions: Can I somehow cut this flush with the cement floor? Secondly, what is the proper method of plugging and sealing this pipe? I appreciate the help.
Hoofman
Old 07-23-07, 11:27 AM
Drain Pipe Fix
O.K. Let's try again. Old Cast Iron waste pipe that needs to be plugged, totally out of commission. Does a plumber need to solder this tight or is their some way for me to plug this myself. Much appreciated.
hoofman
Old 07-23-07, 11:44 AM
Received 25 Votes on 19 Posts
Hammer the pipe to break it off flush with (or slightly below) the floor. Be sure to use a full-face shield, wear long sleeves, gloves and keep everyone else away because cast iron will shatter and send bits quite a distance.
Then shape a tapered wooden plug that you can pound into the pipe at least an inch below the floor surface. Top it with a sand mix concrete or mortar
Old 07-29-07, 10:18 AM
Excellent. Thanks so much for the reply!
Hoofman
HTML code is On
