pressure tank shot?
Old 08-21-07, 03:59 PM
P
pressure tank shot?
With the well pump off and the drain opened to the pressure tank, no water comes out and the tank is full! When I try to check the air water comes out of the valve stem and wont drain out of the tank. Any suggestions?
Old 08-21-07, 07:22 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
Time to replace the tank. No water should be above the weld line. In your case the bladder is ruptured. Give it a decent burial.
Old 08-22-07, 02:12 AM
P
Its a blue aqua air v60, is it the bladder type or other type? I was told it might just have to be forced out with air. Why cant the water drain out? If I do have to replace it, should I buy a bigger one. This one is 20 gallons.
Old 08-22-07, 07:17 PM
chandler's Avatar
Water probably won't drain because of possible sludge build up. Regardless you will want to buy a bladder type to replace it with. The older ones didn't have a bladder and the head space of air was absorbed by the water and you had to drain the tank to create an air space on top. If you have a tire fill valve on top, it was a bladder type.
Old 08-23-07, 02:20 AM
P
Ok. What size should I get?
Old 08-23-07, 04:30 AM
chandler's Avatar
A 20 gallon should suffice for a normal sized house's usage.
