Second discharge line?
Old 08-21-07, 04:22 PM
C
I am planning on putting a second submersible sump pump into my sump hole as a backup. It will be on it's own 15 amp circuit. Is it alright to add to the pvc pipe that I'm using with the original pump, or should I make up a second line? In case of power loss I plan on running two 12 gauge extension cords from my 5000 watt portable generator. Make sense?
Old 08-21-07, 07:19 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
The only thing I could think of is putting check valves in the lines, as one pump will cut on and run the water backwards through the other pump using a common discharge.
