connecting closet flange to soil stack
Old 08-26-07, 02:34 PM
T
I just replaced the subfloor and installed new underlayment in my bathroom. The closet flange came off the soil stack (cast iron) when taking up the old subfloor. Got a replacement closet flange, PVC with the rubber gasket. The soil stack is about 1/2" above the underlayment. The finish floor will be Armstrong cushion step vinyl, about 1/8" thick. Do I need to grind down the stack level with the floor before installing the closet flange?
Thanks!
Theresa
Old 08-26-07, 04:46 PM
A
If the cast iron is above the finished floor, yes you have to lower the height down somehow. Or you will have to build a cutout of the toilet with wood to raise it up to the iron height, which won't look good.
Old 08-29-07, 10:31 AM
T
flange
Thanks, found out the section I was referring to is actually lead. I got it down to the floor no problem.
