ok to use PEX compression rings on PB?
Old 10-14-07, 11:52 AM
T
I have a house built in 96 with mostly PB. I need to remove temporarily one water line that feeds a toilet in order to tile the floor, and then reattach the line afterwards. Can I use the PEX compression rings (1/2) for the PB line? They look identical. I'm not using the ones with the shoulder on them, just the solid ring.
Thx
Old 10-14-07, 03:58 PM
Hmmmm, no reply??? I assume you have the proper fitting tools??? You can't just use a pair of pliers you know. Not sure if the rings are interchangeable.
Old 10-14-07, 04:02 PM
T
was going to rent the pliers to do the crimping. Just waiting for a response
Old 10-14-07, 07:15 PM
5
I think fittings and crimps for PEX are not usable on PB. Not positive, because haven't seen any PB for a long time. The place that is selling the fittings should be able to provide specs. If not, contact the manufacturer.
Old 10-16-07, 07:06 PM
notuboo's Avatar
Fittings should not be interchanged. Crimp ring is different size also.
What does this really mean...it's temporary and it may work...temporary.
Old 10-17-07, 05:50 AM
T
grabbed copper PB crimps, apparently you use the same crimping tool for the PB crimps as you do for pex. seems to be holding.
thx
