Bath Vanity Replacement 1 sink vs 2
Old 11-10-07, 02:35 AM
Post Bath Vanity Replacement 1 sink vs 2
Existing vanity plumbed for one sink. Want to replace top (59", odd size with one sink on left) with 2 sink top. Is it possible to connect to existing plumbing/lines with extentions,flex hose,pvc t, etc?
Thanks
Old 11-10-07, 04:47 AM
chandler's Avatar
Received 11 Upvotes on 10 Posts
Welcome to the forums! You can tie the two sinks together with 1 1/4" drain connections readily available at most home center stores. Not seeing your configuration, I can't tell you exactly which ones you will need, but once the sinks are set in place, you will see what you need and can draw it up and get the pieces you need. When you get to that point, let us know if you need any help. We're here.
Old 11-10-07, 07:03 AM
Received 1,288 Upvotes on 1,226 Posts
Of course you can do this, it's only a little more complicated than the way most two basin kitchen sinks are installed.
Old 11-10-07, 08:00 AM
shacko's Avatar
Smile Vanity Sink
Thanks
Yes you can as long as both go into the inlet of the trap.
I don't think that you can use flex hose, pvc is fine and the most economical, you must remember that pvc is a glue joint so you have to make sure they are lined up. Use a pvc trap with lock nuts on it.
Plan out you hook-up and go for it, luck.
