hole in old black iron sewer pipe
Can we replace the elbow section of old black iron sewer pipe with pvc ourselves without having to call a plumber? hole in pipe now is approximately 4-5 inches in diameter on top of black pipe. we wrapped hole with saran wrap for now. Was told would be over $3000 to fix by a plumber. help.
I'm not a plumber, but the one time I worked with cast iron pipe, it wasn't as difficult as I expected. Assuming everything is accessible, cutting the cast iron pipe is probably the only hard part of the job. You can probably rent a pipe cutter at any tool rental place.
I tied in a new drain line to a cast iron stack. I just cut a section out of the stack and used the neoprene couplings sold at big boxes (Fermco???) to splice in a PVC wye.
A better temp fix would be to take a piece of rubber, wrap it around the hole and secure it with pipe clamps.
Make sure the pipe is properly supported above and below the area to be replaced. Rent a snap cutter and use banded couplers to attach the new PVC section.
Supporting it is the important thing.
