Everpure Filter
Old 12-10-07, 01:53 PM
1
Everpure Filter
Have Everpure H100 filter system. Cannot budge retaining ring whose counterrotation is required to change cartridge. Any suggestions and/or tips?
Old 12-10-07, 11:48 PM
P
first the obvious, make sure the water is off. second, bleed the pressure off of the filter before you try and loosen the ring. even with the water off if the filter is still pressurized it will be very tough to loosen.
paul
Old 12-11-07, 09:16 AM
1
Everpure Filter Change
Thanks p-nor as bleeding system seemed to do the trick. It probably also helped that I realized I had neglected to turn off the right in-line water valve!
HTML code is On
