10' Braided stainless steel hose - Washing machine
Old 12-28-07, 07:14 PM
W
Does anyone know where I may be able to find braided stainless steel flex hose for a washing machine in 10 foot lengths?
Thank you.
Anthony L.
Old 12-29-07, 04:19 AM
chandler's Avatar
Received 7 Votes on 6 Posts
Anthony: welcome to the forums. You don't want to run a flexible pipe that far. Wouldn't it be easier to extend the copper/cpvc from the original location to a washing machine box nearer the location you need it at?
Old 12-29-07, 04:55 AM
the_tow_guy's Avatar
Received 67 Votes on 56 Posts
My first thought was two 6-ft hoses with a coupler, but chandler's right.
Old 12-29-07, 08:38 AM
W
Thanks. Problem is that there's a chimney and a 3" vent pipe in the way. I could run the copper outside of the drywall, but would prefer not. The alternative is to put the washer next to the piping (possible), but it simply utilizes too much space in that fashion. I've already got it set up with a 10' washer hose that I purchased from the local hardware store, but it's not braided stainless. No ideas on where to get a 10' length??
Old 12-29-07, 01:04 PM
Received 98 Votes on 86 Posts
You're going to run a line anyway, cpvc would be more resistant to coming apart on you than a hose - even braided stainless.
Old 12-29-07, 06:43 PM
chandler's Avatar
You will think of us in a year if you run that flexible hose, even stainless braid. Its life expectancy is reduced by every inch of rubber you add to the length. Good point on the cpvc. Easy to work with and work around. Adapt the ends to use a brass ball valve, however. The cpvc ball valves suck for lack of a better term.
