why overflow pipe is dripping constantly?
Old 01-07-08, 03:31 AM
I have recently had a new toilet installed into our apartment as the pan in our old toilet had cracked. Our new toilet does not have an overspill pipe, and now the overflow pipe outside our building is constantly dripping. what should I do?
Old 01-07-08, 04:21 AM
chandler's Avatar
Received 2 Votes on 2 Posts
Are you in the US? What type toilet did you buy, and what type overflow pipe are you referring to on the outside of the house?
Old 01-09-08, 03:04 AM
It could be that turning the water off to replace the old. WC allowed grit or scale to travel along the pipe and be stuck to the ball valve washer or it could just be old and worn out. It should not be an expensive job to re-washer or replace the ball valve. I have also solved my problem from here http://www.tucsonazplumbers.com/plum...services.shtml
Old 01-09-08, 08:52 AM
shacko's Avatar
Toilet prob.
chandler has the same questions I have, are you in the USA?, you are using terms that I never heard of, sorry.
Old 01-09-08, 11:34 PM
why didnít you install new overflow pipe .Almost certainly the ball valve in the WC cistern needs re-washering or replacing. It can be solved , but depends on a number of factors, 1) is the ball valve plastic, 2)is it bottom entry or side entry to the cistern 3) is it brass and corroded etc, if you are not sure I can only suggest you call a plumber!
Old 01-10-08, 09:13 AM
shacko's Avatar
toilet prob.
myrona: Since you seem to know what the original post was talking about it would be nice to explain what the Non-USA? terms mean.
HTML code is On
