Plumbing issue - hot water
Old 01-07-08, 05:47 AM
Good day all, my house is a 2 story. The tub/shower in the guest bathroom is rarely used (second floor). It is a single handle faucet. When the handle is turned all the way to the hot side just a trickle of water comes out; full force of water on the cold side. FYI the sink is two handles and both water sides work.... Suggestions on how I can check out the issue would be appreciated. Thanks, Kim
Old 01-07-08, 06:45 AM
Had the same issue with my guest bath last month - ended up replacing the cartridge for the faucet assembly - and it now works perfectly. You should be able to find replacement cartridges at a big box store and/or plumbing supply house.
HTML code is On
