Saddle Valve leaking
Old 01-13-08, 07:04 PM
T
I installed a saddle valve to tap in the hot water pipe for my humidifier. However the valve started leaking after a couple of days, the water is coming out from the top of the valve. i think the water pressure might be too high, not sure though.
I wanted to know what I could do. Is there a better solution than a saddle valve.
The CPVC pipe that the saddle valve is attached to is a 3/4" pipe. I wanted to know if i could put some kind of a T section. I need a 1/4 connection for the humidifier.....I think it is the same connection that ice maker kits use.
Thanks
AJ
Old 01-13-08, 07:23 PM
Terd Herder's Avatar
Cut in a 3/4x3/4x1/2 tee, stub out about 6" of 1/2 inch cpvc pipe with a 1/2 inch male adapter then a 1/2 (female)x1/4 compression angle stop. Use pipe dope. Good luck!
Old 01-13-08, 08:14 PM
T
That was way too fast for me. I am really a beginner at this.
1. I understand I need a T with 3/4" inch opening on two sides and 1/2" out.
2. Connect a 6" pipe to the 1/2" opening on the T.
3. what is this 1/2 inch male adapter and the 1/2 (female)x1/4 compression angle stop. Where can i buy these? I wanted to know what these adapters look like?
Thanks
Old 01-14-08, 08:41 AM
T
Ignore my last post, I did some research on internet on the parts you listed. I still have a couple of questions
1. 1/2 inch male adapter: is the one below the correct type, meaning can both sides be CPVC or does one side have to be metal?
2. 1/2 (female)x1/4 compression angle stop: Is this what you mean?
3: Would I use pipe dope on the threads to connect the cpvc male to the 1/2 (female)x1/4 compression angle stop.
Thanks in advance for your help
Old 01-14-08, 11:02 AM
BTW, for future reference, saddle valves are with prohibited in some jurisdictions, including Illinois (IPC Section 890.1130 ), and if they leak insurance may not cover the damage.
Old 01-14-08, 02:46 PM
You got that right. Bad news too, never shut off either.
Your part pics are correst.
Glue the male adapter on the 6 inch long piece, apply pipe dope on the threads, screw on the angle stop. Use a little dope on the threads of the 1/4 as well.
Use cpvc cement/primer, make sure pipe is drained and areas glueing are dry as well. Good Luck!
FWI Buy a couple male adapters...sometimes screwing them on can be a pain-they get stripped. Just in case.
Old 01-14-08, 05:22 PM
T
Last question. Like you mentioned, I am also afraid that the cpvc threads could get stripped when screwing the angle stop. I found a transition male adapter at Lowes, do you think this one would be better than the cpvc one?
Thanks
Old 01-14-08, 08:07 PM
Sure, brass to brass...cannot go wrong. Good luck!
Old 01-16-08, 01:14 PM
A
Avoid anything with plastic threads for pressure piping. That brass x cpvc transition is exactly what you'd need. You can also find shutoff valves that connect directly to cpvc - you cement them on directly to the pipe, then connect your icemaker. Oh, I'd lose the plastic icemaker line, get a braided stainless steel one instead.
