fitting question
Old 01-14-08, 07:27 PM
fitting question
Hello all,
I'm installing a whilrpool RO system. My question is, what kind of "T" do i need to tie into the "blue" RO supply line (3/8" OD & Plastic) with the 1/4" compression (braided stainless) from the fridge icemaker?
I've only found brass compression (3/8 coupling w/ 1/4" T) fittings. Will these work with the plasic RO line?
Old 01-14-08, 07:37 PM
You should not use any metal fittings on RO filtered water. If the "blue" is the outlet, you need to use plastic fittings.
Old 01-14-08, 07:54 PM
594-
So, what is the fitting called that allows you to tie into the 3/8 OD plastic line and has a male 1/4" compression thread to screw on the braided line to the icemaker?
thanks
HTML code is On
