Replace PVC tee with straight run
Old 01-27-08, 01:42 PM
R
I'm removing a bathroom vanity and it will not be replaced. The sink drain enters a 1 1/2 inch PVC drain line via a tee fitting. I'm planning to simply cut the tee out and replace with a straight run (as if the sink had never been there).
What fittings should I use to do this? In my limited PVC piping experience, the fittings set up very quickly, so I don't think I will be able to use 2 couplings plus straight pipe.
Thanks for the help with this very basic plumbing question. I searched the internet and did not find the answer.
Bob
Old 01-27-08, 04:30 PM
Received 1,290 Upvotes on 1,228 Posts
Why not leave the T and just cap it off where you removed the sink drain?
Old 01-28-08, 05:49 AM
R
The tee projects into the room, so if I just cap it off, I will not be able to close up the wall with sheetrock.
