Replacing shut off valves (the pull type)
Old 01-30-08, 04:06 PM
E
I have a 10-year old home and the home builder decided to install these plastic casing water shut off valves under the bathroom sink that you pull to shut off and push to allow water back in vs. the normal "turn the knob" version we see sold everywhere.
I want to change the hot water line (it's leaking a bit) but it's part of the shut off valve - the water line can't be removed by simply turning a screw-type device. Have any of you had experience with removing this type of shut off value. I think my pipes are copper. I want to ultimately replace it with a normal shut off value so I can change the water line much easier next time.
Old 01-30-08, 05:52 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
If you turn off the water to your house, you can change out the inferior valves all at once. I am not sure if they are soldered on or if held in place via a compression fitting. Would be nice to know. You can cut the pipe just below the existing fitting and install new stop valves using compression fittings which will allow you to change out the hoses to your sink much easier. Let us know if you need further help on this.
Old 02-05-08, 07:45 PM
A
Relacing shut off value pull type
Ed
Did you find out how to remove those plastic values? I have the same problem although it is the value that is leaking and I am able to change the water line.
Thanks
Steve
