Commercial flush valve toilet replacement
Old 02-25-08, 03:35 PM
E
I live in an old building and our toilets are the commercial style. I need to replace it but it looks like a new commercial toilet has the water supply spud from the top, my old one is from the back.
From the dimensions on the new products it looks like I will need to extend a pipe out, and possibly raise it (hopefully not). Questions I have:
1. It looks to be black iron pipe, but I've searched and this isn't suppose to be used for cold water supply. What should I change this to? The pipe is 1 1/4".
2. It's threaded so I'm hoping there will be a variety of sizes to make a good fit. If not, do I have other options for fitting it to size?
I've thought about changing this out to a standard toilet, but it doesn't look like I have a way to connect a standard water supply. There's not enough clearance, and I don't see how to cap the black cold water pipe. It extends back into my neighbors unit.
Old 02-25-08, 06:49 PM
Terd Herder's Avatar
They do make offsets for the vertical pipe to fit into the spud of a new toilet. If that wont work, pull everything out back to the tee in the wall, extend out far enough to fit the new toilet. Looks like fun!
Old 02-25-08, 07:15 PM
E
I'm hoping the height will be ok, it looks like there's barely enough room. I guess my main problem is replacing that pipe that extends out. What kind of pipe am I suppose to use nowadays, and are there a variety of sizes with double ended threads? It looks like I need something around 2 inches longer than the current pipe.
Oh, I'm having tons of fun. Headache inducing, nightmare like fun.
Old 02-26-08, 05:13 PM
You can still use galvinized. I would use copper with a brass nipple threaded into the existing plumbing to prevent corrosion.
