shower and tub leaks
I replaced the faucet stems in both bathrooms, tub and shower and put in new shower heads in both baths as well. I wrapped the rod threads with tape on the shower heads but not the stems. The shower leaks (runs into the dining room next to it) in bathroom #1 but not the tub. I can use the shower in bathroom #2 if I don't turn the water up much. But if I turn on the water hard it leaks too. Any suggestions out there? I need help please.
What do you mean by "stems"?
If you're talking about the pipe coming out of the wall..... you should have used pipe dope/teflon tape on those threads as well.... Then tightened firmly with a pipe wrench (using a rag between the teeth to keep from scratching the new finish)....
shower and tub leak
Thanks for the info. The "stems"? are what I called the gizmos that fit into the wall, then the faucet handles screw onto them. I have a set of plumbers sockets? that I remove them with. I am going to retape all the handles and try that. Should I use tape or plumbers putty? This is my weekend project...if that doesn't work I guess a call to the plumber is next. Thanks again.
