Washing machine drain relocation
Old 03-08-08, 08:58 AM
C
I am moving my washer 30' from its current location in the basement. There is no drain on that side of the house, so I thought to install a 1 1/2" drain line above the finished ceiling travelling over to the existing drain with the proper pitch. My questions are:
1) Will a GE Washer Model WJSR2080T5WW pump up to 7'?
2) Do I need to vent the line
3) I will install a check valve at the outlet of the washer
4) The 30' run will end with a 90, then a 4' 1 1/2" down pipe into the existing drain. Will that back up?
If this will not work, what else can I do? I'm not running the drain line on floor level due to a doorway.
Thank you
Old 03-08-08, 10:07 AM
F
Received 39 Upvotes on 31 Posts
1. Maybe, maybe not. You would need to get GE's blessing on this.
2. Absolutely! You also need a trap at the point of inlet.
3. Why?
4. Probably. Most current washing machines require a 2-inch drain line.
Old 03-08-08, 10:21 AM
Simplest solution is a pumped tub or standpipe:
http://content.managemyhome.com/Imag...ing/1658_R.gif
They make self-contained units which can be connected directly to the tub or washer, for example:
http://www.westsidewholesale.com/ind...012&source=ad1
What you want to avoid is something like this:
Incorect washer standpipe - Paragon Inspections Wilmette / Chicago Ill
