Replacing an outdoor faucet
Old 04-30-08, 06:35 PM
I've got a broken outdoor faucet and need to replace it. It's the type that has a pressure relief valve for freeze protection, and the pressure relief portion is broken, if that makes any difference. It's mounted on a brick wall. Is this as simple as turning off the water to the house, getting a wrench and unscrewing the old faucet and screwing on a new one? Or is there more to it than that?
Old 04-30-08, 07:31 PM
plumbingods's Avatar
Hi there, and welcome
Unfortunately, this is usually not quite that simple.
The broken part has nothing to do with the freeze protection, it is called a vacuum breaker and is there to protect your drinking water from contamination.
The long length of the sillcock is how it is freeze protected.
The handle is connected to a rod going through the pipe to the other end. That is where the shut off part of the valve is, so it cannot freeze. Provided it is pitched properly.
Most plumbers do not use the threaded way to install the sillcock (outside faucet), these are usually soldered in place. And becauce it is going through brick, you may have some problems if the brick was installed after the sillcock because there may be mortar keeping it in place. If the sillcock was installed after the brick you will probably be ok.
If your sillcock has a large grey plastic knob it is most likely a mansfield and they do sell a repair kit for the vacuum breaker on the top of this brand sillcock.
If replacing the valve, make sure it pitches towards outside and make sure to take the hose off in time before things start to freeze and the sillcock should not break. Even though dirt can be the problem sometimes.
If you are not used to soldering you can get a fitting that threads onto the sillcock and a compression fitting to match the pipe size you are dealing with, generally 1/2".
Hope this helps you out, Mark
Old 05-06-08, 09:38 PM
Pitch??
Plumbingods,
Can you explain what you mean by "make sure it pitches towards outside"? Do you mean that the angle is raised on the inside and pitching downwards as it goes through the wall?? Am I way off base?
Old 05-06-08, 11:28 PM
That is exactly correct. Otherwise the sillcock stays full of water and can freeze.
HTML code is On
