Humming pipes
Old 12-26-99, 03:00 PM
Guest
Unhappy
Shutting off faucets or flushing toilets produces a humming like noise. Appears to occur more consistenly as the day progresses. Any d-i-y solution?
Thanks
Bob - the Unhandy Man about the House
Old 12-26-99, 03:16 PM
Guest
Post
Sounds like your pressure regulating valve,
which is commonly located on the water line
where it first enters your house,has a
pyramid dome shaped piece on the top of it.
Another location is in the same room as
the waterheater.Im certain this is the root
of your problem.
hope that helps,need more advice Im always here.Robert
