Hole in pipe
if you are speaking of the supply line
under a sink that leads from the shut off
valve up to the faucet,then a standard
flare or compression adapter will work
great.if you are speaking of a supply line in a basement,perhaps one of your main lines,
a soldered connection is always best,if the
leak is on a hot water line do not use any kind of dresser coupling!now may be a good
time to take soldering lessons.
if soldering is not an option then you may use a compression coupling
[This message has been edited by GARPLUMCO (edited January 03, 2000).]
