well pump
Old 01-07-00, 10:39 PM
Guest
Question
my house has a well and the power went out the other day. my kitchen and upstairs sink and toilet will not get water coming out of the fixtures. all my downstairs facilites work eg. shower toilet and sink.what is the problem are the lines clogged or do i have to reprime my pump. would appreciate it much if you could help...thanks
Old 01-08-00, 12:40 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Post
Sounds like you need to re-prime your pump. The check valve on the well- side line of your pump should hold water up so that you don't have to fill that. A defective check valve may be the reason that you lost prime. The water in your downstairs is probably just the water in the lines draining down from upstairs.
