No Hot Water
Old 01-12-00, 12:09 PM
Guest
Unhappy
I have had no hot water for a couple of days. Before I call a repairman, I wanted to know if there is anything I can check or replace myself. My water heater is electric. I did check the fuse boxes to make sure they were working.
Any suggestions would be appreciated.
Thank you
Old 01-12-00, 08:35 PM
Guest
Post
you'll need a meter to accuratley test
the elements and the thermostats.
you can also try removing the upper cover
on the heater and pressing the red reset button,the heater may of over heated and
tripped it.
