Running toilet bowl
Old 02-02-00, 10:34 AM
Question
I recently installed a new toilet. It runs okay and the tank fills with water like it should and stops, but the problem is the toilet bowl continuously runs water all the time. What is wrong? and what can I do to fix it?
Old 02-02-00, 01:49 PM
Post
purchase a bottle of the blue liquid
tidy bowl and squirt some in the back of the toilet(the tank) do not let any get down the overflow tube.wait about 30 minutes if it takes that long,and if the water in the bowl becomes blue that will tell you that the flapper is allowing water to pass.
also be sure that the water is not all the way at the top of the overflow tube.
do not flush the toilet until you have tested
HTML code is On
