plumbing rough-in
Old 02-21-00, 06:12 AM
Guest
Question
For upstairs master bath, the access for double lavs will be only in one place for both 3/4 lines (with 1/2 tee's). The stud wall is non-load bearing, can side by side 1/2 inch holes be used to reach both lavs?
Or do I need to go with one above the other.?
Engineered floor joists prevent another access.
Old 02-21-00, 05:23 PM
Guest
Post
I HAVE AN IDEA WHAT YOU ARE SAYING BUT NOT
ENTIRELY SURE,CAN YOU WORD ANOTHER WAY.
Old 02-21-00, 05:39 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Smile
I would go with one higher than the other for easier clearance (hot water on the left, cold water on the right..cutoff valves on all four). Good luck!
Old 02-22-00, 05:17 AM
Guest
Post
Apparently I will have to sister a couple of studs to those that I drill two 5/8's holes through because that is more than 1/2 of a studs 1 1/2 inch thickness.
Old 02-22-00, 06:18 PM
Smile
Dave:
You have to be a little more specific for us to help you. O.K.?
