is water pump pressure adjustable
Old 02-21-00, 08:12 AM
Guest
Question
low water pressure on hot+cold in entire house. it is all copper piping, also we had a water softener installed (but didnt effect pressure)i was wondering if the water pump is adjustable its at 25 psi now-normal??theres a long bolt protruding from the side of the water pump case could this be an adjuster??i havnt moved it to find out what is yet.what psi is safe to run at?
Old 02-21-00, 04:43 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Smile
25 psi may well be the low pressure specified for that water pump by its manufacturer, but your water pressure can be set higher. The threaded stem sticking out is probably the pressure control valve stem. Try loosening the lock nut at its base, and screwing it in or out to adjust the cut-off (higher) pressure. You also can adjust on/off pressure by adjusting the two spring retaining nuts up and down in your pressure switch. If you have an air tank, check the pressure with a tire gauge. It should be just at or below the 25 psi kick -on pressure. If it's low, recharge the tank with a portable air tank. If you're like me, when all else fails, contact the manufacturer for guidance (see pump plate). You should be able to have much higher water pressure safely. Good Luck!
Old 02-21-00, 08:37 PM
Guest
Thumbs up
thank you very much for the advise is there a maximum psi i should watch out for??
Old 02-22-00, 04:58 AM
Smile
Your normal house plumbing should be way more than adequate for any max pressure that a regular 1/2-hp or 3/4-hp water well pump can generate. Unless you have some Godzilla pump not meant for a home, just adjust it up to where you like it for the upper pump cutoff pressure. It's only going to get so high, anyway. Should be O.K.
Old 02-23-00, 06:07 PM
Guest
Unhappy
Well i tried adjusting the pump today, turning that long bolt in and out...feels like its turning a spring, but it didnt help the pressure at all....oh well
