water pressure
Old 02-27-00, 07:10 AM
G
Guest
Unhappy
I`ve been having trouble with my home`s water pressure.The pressure switch will not kick on when needed.We go from seconds to hours without water. This happens very often when the temp. outside is relatively warm. When it`s very cold outside,this problem never occurs.What should I do
Old 02-27-00, 10:00 AM
L
Post
Do you have well water?
Dave
L.I.Handyman
Old 02-27-00, 12:30 PM
G
Guest
Post
<HR>
I do have well water
Old 02-27-00, 05:31 PM
Mike Swearingen's Avatar
Cool
Check and adjust pressure switch (by adjusting spring-loaded nuts up or down). If you have a pressure tank, check air pressure in tank with tire pressure gauge (should be at or just below kick-on pressure setting).
HTML code is On
