Tapping into an existing waste line
Old 02-27-00, 07:09 AM
Question
I'd like to move my laundry to the basement. Can I tap into an existing 3" vertical waste line with a "T", directly above a clean-out, so that I can add the laundry tub/sink?
Old 02-27-00, 07:40 AM
Mike Swearingen's Avatar
Cool
Sure. Recommend using a sanitary T (aka street T), which directs force of flow in the direction that you want it to go. Good Luck!
Old 02-28-00, 01:15 PM
Post
BE SURE THE STAND PIPE IS AT LEAST 36 INCHS
HIGH.YOU MAY WANT TO CUT THE CLEAN OUT OUT
AND LOWER THE TEE YOU ARE GOING TO INSTALL AND PUT THE C/O OVER THE NEW TEE
HTML code is On
