clogged pipe
Old 03-15-00, 08:55 AM
Guest
Angry
I have replaced pipe under bathroom sink and while looking in pipe in wall I have noticed a lot of rust. All pipes have been replaced by copper within the last 2 years. The drain has always been slow. What should I do?
Old 03-15-00, 12:04 PM
Mike Swearingen's Avatar
Post
Sounds like you have galvanized drain pipe with typical internal scaling problem, restricting drain flow. Need to replace with PVC plastic pipe to solve it.
Old 03-15-00, 11:54 PM
L
Post
You're talking about the drain pipe, inside the wall, that has the rust? If so, replace it with ABS (the black plastic pipe) for as far as you need to. You can convert from the ABS back to the original galvanized iron either using a threaded adapter or a neopreme coupling where the two meet.
HTML code is On
