Vent pipes and turbine caps
Old 07-13-08, 10:04 AM
W
Has anyone ever used one of the winddriven turbine type caps on a plumbing system vent? Trying to find a good way to keep the leaves and squirrel stuff out and perhaps increase venting some?
Old 07-13-08, 10:51 AM
chandler's Avatar
Received 10 Upvotes on 9 Posts
It would be a little difficult to fit 10" or 12" turbine on a 2" vent pipe and keep it balanced. One way to keep the crud out would be to install a piece of screen over it and securing it with a worm gear clamp and trim it up. Another method I have seen is to obtain the bottom half of a 2" S-trap and set it on top of the 2" (don't glue it, as you may have to remove it sometime to clean out the vent.) Friction and gravity should hold it in place.
Old 07-13-08, 12:36 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Why not just put any number of styles of vent caps on it?
Properly installed vents don't need additional venting, nor would they be desirable I would think.
