copper pipe repair
I have an old house built in the 50's with copper pipe. The initial repair I'm looking at is under the kitchen sink, there are no water shut-off valves. So I run down to Home Depot, the guy gives me a pair of cut-off valves. I go back home, cut the pipe cleanly and put them on per the directions. The problem is that where the copper pipe comes into the bottom of the valve leaks back past the brass (compression?) fitting.
I have a torch and wonder if I should seal up the end of the nut where the water is coming out with solder? Or should I just remove the nut, cover the fitting with teflon tape and put it all back together?
i would not solder a compression fitting. I know the directions say not to use pipe dope on many of them but plumbers do use it. Take it back apart and put a little pipe dope on the threads, This will lubericate it as you tighten. I do this whenever I have a leak on compression and it always works.
