Moanin'about Moen in the Kitchen sink
Old 04-29-00, 10:36 AM
Guest
Post
After replacing the Pivot retainer on my Moen One Touch Single Control Kitchen Pullout Faucet, Model 7385- I had less water flow. I have checked the Screens on the Spout removed the Spout still low flow, cleaned the screen on the Hose under the sink and now I'm down to a trickle. disconnected water connections to faucet tubin and checked shut off valves on hot and cold water inlet. Flow is excelent. Figure it is time to replace Cartridge in Faucet. I have Moen's Illustrated Parts picture and have removed the Retaining clip but It apparently does not retain the cartridge. How do I get the cartridge out? I have consider plastic explosives but believe that to be to drastic.
gnl
Old 04-29-00, 02:20 PM
Guest
Post
That clip does hold the cartridge in. They do pull out hard though. One thing I have done in the past is to use a faucett handle so I have something to grab on to and that has always worked. I think there is a puller if you need it to.
Old 04-30-00, 07:23 PM
Wink
They do make a cartridge puller for Moen,try your local hardware store.
Dave
L.I.Handyman
Old 05-01-00, 07:19 PM
Jacksprat
Wink
About two years ago, I called Moen to fax me a parts breakdown, half hour later Rene the Moen service guy, was ringing the bell. Replaced the entire unit. No charge. Something about Moen's lifetime warranty! Call them.
HTML code is On
