How would you Design the Shower
Old 04-26-00, 09:03 AM
Lightbulb
I want to make a shower that is like you are in a rain shower. the water would just drip down on you in a steady stream. My idea is to run pipe overhead and drill small holes in it or to put in the mister heads.
What ideas do you have?
Old 04-26-00, 08:06 PM
Post
ARE YOU RETROFITTING AN EXISTING SHOWER ??
Old 04-27-00, 01:10 PM
Thumbs up
Yes I am retrofitting an existing shower.
Old 04-29-00, 11:01 PM
Post
RUNNING THE PIPES OVERHEAD WOULD DO THE JOB
IF YOU INSTALL THEM IN AN ARTISTIC FASHION,
MAYBE A LOOP CONSTRUCTED OF SOFT COPPER.
OR YOU CAN TEAR THE WALLS OUT OF THE SHOWER
AND INSTALL SOMETHING FROM HANS GROEH,
THEY HAVE A NICE LINE OF SHOWER VALVES WITH
BODY JETS, AND WHAT YOU ARE DESCRIBING.
Old 05-01-00, 01:57 PM
Post
Thank you for the Advice!
Old 05-01-00, 02:38 PM
Post
It's spelt Grohe not Groeh
Grohe is made in Germany and the parts are expensive to get replaces.
Meon is the best.
By The Code Plumber
Old 05-01-00, 05:33 PM
Post
Meon is the best.
By The Code Plumber
And you can spell? MOEN not meon, kind of like moron, in what you are over the toilet flange. Listen to GARPLUMB he's one of the best. I recommend him from my plumbing wholesale co. all day long and have never had a complant.
ps: Just because you have a plumbing license does not mean you know everything. I know people with drivers license's that can't drive worth a sh&% either.
Old 05-01-00, 06:21 PM
Post
Yep you are a moron arn't you, your not a plumber so shut the hell up.
GARPLUMB don't know crap when it comes to plumbing, he does things like a handyman, there are codes and he breaks them all.
I worthless no good plumber, he is, he thinks his fixes will work, well he's wrong and will always be worng
By the Code Plumber
Old 05-03-00, 07:59 PM
Post
IF YOU PURCHASE THE GROEH VALVE IT WILL NEED
NO REPAIR FOR A LONG TIME.AND PARTS ARE NOT HARD TO GET, IT IS THE MERCEDES OF FAUCETS.
Old 05-03-00, 08:11 PM
Cool
Go Mac
Old 05-05-00, 02:13 PM
Post
Moen is garanteed for life and the parts will cost alot less the moen when you need it repaired, moen will out last grohe anytime.
By The Code Plumber
Old 05-05-00, 05:19 PM
Post
MY MY MY. Such unrest in the plumbing department.
Jack the Contractor
Old 05-05-00, 05:20 PM
Post
quote:
How is Jack doing?
By The Code Plumber
HTML code is On
