new fixtures for shower
Old 05-17-00, 05:36 PM
Guest
Post
I would like to replace the tub/shower controls in my bathroom, as they are showing their age. The Price-Pfister single-control fixture has the shower diverter built in to the flange. However, any new fixtures I have seen have the diverter on the tub faucet. Where can I find a replacement trim kit so that I can update the look of the fixtures without having to replace the whole fixtures?
Old 05-17-00, 05:41 PM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
quote:<HR>Originally posted by WhiteColin:
I would like to replace the tub/shower controls in my bathroom, as they are showing their age. The Price-Pfister single-control fixture has the shower diverter built in to the flange. However, any new fixtures I have seen have the diverter on the tub faucet. Where can I find a replacement trim kit so that I can update the look of the fixtures without having to replace the whole fixtures?<HR>
Have you tried Price Pfister web site?
Best Regards Plumber2000
www.atozplumbing.com
Old 05-17-00, 06:39 PM
Guest
Post
Yes, I checked there, but they only seem to carry models with the faucet diverter nowadays (as does every other vendor - Moen, American Standard, Delta, that I've checked).
Are the flange-diverter type not made any more?
Old 05-17-00, 06:43 PM
Post
<HR>
Well they may not, you could have the trim refinished, I'm sure there are places to have this done.
Last resort is to replace the valve with a new one.
Old 05-17-00, 10:13 PM
L
Received 1 Upvote on 1 Post
Post
It could be that the mfgrs have all gone to the diverters on the spout. However, if you replace the entire tub/shower valve, the new one will be pressure compensated, so nobody gets scalded when they are taking a shower and a toilet gets flushed, or a glass of water gets drawn in the kitchen. That may make the diverter on the spout seem like small change!!
Old 05-18-00, 10:59 AM
Guest
Post
Replacing the spout and the shower head shouldn't be a problem, but how big a chore is it to replace the valve, i.e., is it a DIY project? I'm pretty sure there is a way to access the plumbing without ripping out the tub/enclosure (there is a closet next to the tub where I think I could access it).
Old 05-18-00, 12:47 PM
Post
Replacing the spout and the shower head shouldn't be a problem, but how big a chore is it to replace the valve, i.e., is it a DIY project? I'm pretty sure there is a way to access the plumbing without ripping out the tub/enclosure (there is a closet next to the tub where I think I could access it).<HR>
Open the wall up, you should be able to see the connections, it is not an easy task replacing a valve, if your not sure about it call in a plumber.
