new water service
I recently had to repair a lind in the main water service to the house near the meter.
The house sets approximately 500' from the meter and has a 1" service.
Before covering the hole for the recent repair, the thought occured that I have a garden area about 200' from the meter that I would like to have service to a faucet.
Can I tap onto the main service with a T to run a new supply to this area?
I have service to another garden area but it comes from the service inside the house and not prior to.
Does the code allow this?
Hi:rowlandrw
By all means do so. As long as the water line is downstream of the meter <On your side> it's perfectly fine.
It's best if the intended water supply for ALL outside area's of the house come directly from the main supply line.
This will allow for a full supply to the intended area and you will not have the flowing water noise inside the house.
Word of CAUTION:
Install anti-siphon valves on ALL outside lines! This will prevent any contaminates in the gardens/yard from being drawn back into the lines went you turn them off.
Good Luck
TomBartco
Word of CAUTION:
Good Luck
TomBartco
