outside faucet
Old 05-27-00, 06:41 PM
Post
I want to install an outside faucet can plastic be joined to copper than back to
add the faucet. I want to use plastic because its a long run and its only to be used as
a garden hose
thanks Mark
Old 05-27-00, 08:43 PM
Plumber2000's Avatar
Post
a garden hose
thanks Mark
Yes you can join plastic with copper, you will need to sweat in a copper female adaptor off a copper tee, then use a 1/2" cpvc brass adaptor, from there start the run to your faucet. The plactic pipe if under the house has to be cpvc, not pvc.
Best Regards Plumber2000
www.atozplumbing.com
[This message has been edited by Plumber2000 (edited May 27, 2000).]
HTML code is On
