Water main
Old 08-11-08, 07:21 AM
T
Water main
The water main getting into the house has a leak that I would like to repair. The pipe is the black plastic pipe 1"( CTS or similar). I did the damage when digging for a new addition.
I'm trying to use two compression fittings and in between the fittings PVC or copper since to be able to use the same type of pipe that I have I need to buy 200'.
My question it is possible to do it the way that I have explained or is there other way?
Thanks
Old 08-11-08, 09:39 AM
F
cut a small peice off the pipe. take it with you to the plumbing supply store. not ho depo. andask them to give you some barb fittings to fit this. hand it to him.
Old 08-11-08, 10:48 AM
T
Thanks, but what kind of pipe will you use between the fittings?
Old 08-11-08, 11:28 AM
F
pvc but you will have to get transistion fittings from barb to pvc or at the supply house ask him if he has a peice of scrap hanging around. talk to the guys, they will help you out
ho de won't help you they either have it or not. no lookeing for a scrap you will have to buy the whole thing
Old 08-11-08, 07:11 PM
T
Thank you, all done, we went to the plumber supply and bought the piece of pipe that I need , it was a piece that was hanging around, thank for the suggestion and the help.
HTML code is On
