well pump running
Old 05-27-00, 08:17 AM
Guest
Question
I have well water and the pump runs all the time. The pump is watered logged and I need to no how to drain the tank and repair the problem. Thank you if you can help.
Old 05-28-00, 10:43 AM
Guest
Post
I need more info on your water system ie
where is the tank located, pump located
etc.
Old 05-28-00, 11:09 AM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
If your pressure tank is waterlogged, then all you have to do is get a portable air tank and re-pressurize it, if the bladder is o.k. This will force the water out of the tank. There will be a fitting just like on a tire, and you can check pressure with a tire gauge. Pressure should be just above your cut-on pressure (probably 30-35 lbs psi). Good Luck!
Old 05-29-00, 09:44 AM
Guest
Post
[QUOTE]Originally posted by elmer:Hi Elmer
the pump is located in a crawl space.
Old 05-29-00, 09:31 PM
L
Post
Not a very good place to have your pump located. That's why it's not legal!!
<HR>
Old 06-01-00, 09:58 AM
Guest
Post
it's legal to have a pump in a crawl space. please don't write back unless you can help.
[This message has been edited by carla cline (edited June 01, 2000).]
