Dishwasher
Old 06-03-00, 11:10 PM
Angry
I am installing a new dishwasher. I have installed the t connector and am trying to put in a shut off valve in with a compression fitting, But it keeps leaking so afetr 3 or 4 times of re-adjusting. I turn the water back on and the will not stay on it just gets blow off. Any suggetions
Thanks
Old 06-04-00, 12:30 PM
Post
Exactly where is all of this leaking occurring? Under the sink, or at the dishwasher end? If it's under the sink, install a two outlet shut off valve on the hot water pipe coming out of the wall. One outlet feeds the sink faucet and the other feeds the dishwasher.
Old 06-04-00, 12:31 PM
Post
Also make sure you are seating the copper tubing all the way into the compression fitting. Should be about 1/4 of tubing extending out past the ferrule
HTML code is On
