singing pipes
Old 06-04-00, 07:28 PM
Post
Recently, whenever the toilet it the master bathroom is flushed, as the refill cycle finishes, the pipes it the wall behing the toilet start to whine loudly, until the fill is finished. Any thoughts on a solution?
Old 06-04-00, 10:33 PM
Post
Replacing the fill valve (ballcock or Fluidmaster type) will probably cure the problem. If not, try replacing the shut off valve that supplies the toilet. Those are the 2 most likely culprits.
HTML code is On
