Cut sheet for Kohler Power Assisted Flush Toilets
Can you help. I am a housing maintenance contractor at the US Naval Academy in Annapolis. I have a toilet that is in need of repair. It is a push-button power flush toilet. Can you provide a "cut-sheet" on power flush toilets or help in repairing? The toilet has very low pressure when flushing
quote:<HR>Originally posted by ImageAnnapolis:
Can you help. I am a housing maintenance contractor at the US Naval Academy in Annapolis. I have a toilet that is in need of repair. It is a push-button power flush toilet. Can you provide a "cut-sheet" on power flush toilets or help in repairing? The toilet has very low pressure when flushing<HR>
Thet have a web site at www.kohlerco.com look up the type of toilet it is and there are spec sheet to look at.
Maybe there is debrie in the supply line to the toilet, have you checked by disconnecting the suppy line and pointing it into a pail, truning the water on to see if the pressure is there?
Best Regards Plumber2000
www.atozplumbing.com
