bathroom sink drain stopper removal
Old 06-18-00, 08:14 AM
Guest
Question
I want to check/clean the drain stopper in a bathroom sink, as it drains very slowly. The open/close arm is attached below the sink, can it just be unscrewed from the drain plug or will I need a special tool to remove or reconnect the stopper?
Old 06-18-00, 09:46 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
quote:<HR>Originally posted by scarlett:
I want to check/clean the drain stopper in a bathroom sink, as it drains very slowly. The open/close arm is attached below the sink, can it just be unscrewed from the drain plug or will I need a special tool to remove or reconnect the stopper?<HR>
There should be a nut on the back side of the popup assembly under the sink, loosen the nut up and pull the rod to the rear, then lift the plunger out.
Best Regards Plunber2000
www.atozplumbing.com
