Delta mixing valve trouble. HELP!
Old 06-23-00, 03:37 PM
Guest
Question
I am having a problem with a Delta Shower mixing valve. It is nearly five years old and is beginning to slowly stop my hot water flow. for some reason the hot water flow even when turned fully on is barely pouring out. can this be reapired? Can I do it myself? How? thanx James
Old 06-23-00, 04:37 PM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
quote:<HR>Originally posted by ez4u2nv:
I am having a problem with a Delta Shower mixing valve. It is nearly five years old and is beginning to slowly stop my hot water flow. for some reason the hot water flow even when turned fully on is barely pouring out. can this be reapired? Can I do it myself? How? thanx James <HR>
It might be the cartiage need replaced, shut watre down to house, take valve apart and take cartiage to your home center, get a new one and reinstall it, see if that solves the problem.
Best Regards Plumber2000
www.atozplumbing.com
