smelly sink
Old 06-28-00, 12:07 PM
Guest
Post
My main bathroom sink smells like fish. We have tried to put CLR and bleach down it but it still stinks. We are on a well. Please help Thank you
Old 06-28-00, 03:46 PM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
quote:<HR>Originally posted by skratz:
My main bathroom sink smells like fish. We have tried to put CLR and bleach down it but it still stinks. We are on a well. Please help Thank you<HR>
Is it from the water or comming from the drain, this smell?
Best Regards Plumber2000
www.atozplumbing.com
Old 06-28-00, 07:14 PM
Guest
Lightbulb
Hi:skratz
Just my two cents worth here.
Check the overflow hole in that sink. Possible the smell is coming from it.
Pour in some bleach and then check it the next day. Smell should be gone.
If so, then try to flush out the sludge and slim that usually builds up in those overflow holes. You might also try some CLR cleaner in there also.
Good Luck,
TomBartco
Personal Quote:
"Without having experience or knowledge, my common sense and wisdom often helps me to prevail."
Old 06-29-00, 08:39 AM
Guest
Post
<HR>
The smell is in the drain. The water seems to be fine.
Old 06-29-00, 08:48 AM
Post
<HR>
Try too clean out the overflow in the sink, and do as Tom said.
Old 06-29-00, 06:57 PM
Guest
Thumbs up
Thanks guys for your help. So far the bleach in the overflow hole seems to be working.
Again Thanks
